Compatibility
Liam4
Hello!
Will the Samsung galaxy a52 work with public mobile. I was having trouble trying to figure out their compatibility page.
Thanks!
2 REPLIES 2
HI @Liam4   Yes, A52 will work on PM
It's better to get the Canadian /US version of it then other regional version.  If regional version, it might not work as well,
Meow
Check here: https://www.publicmobile.ca/en/bc/get-help/articles/check-your-phones-compatibility
As long as your phone can handle PM's frequencies you will be OK. And I am sure phone will work being new one (introduced in 2021).
