02-22-2024
09:23 PM
02-22-2024
09:29 PM
computergeek541
I have problems with internet service and calls ....Does anyone know something
02-22-2024 09:37 PM
02-22-2024 09:36 PM
Hello there, I'm in toronto
02-22-2024 09:33 PM
if you are in Manitoba around Ste Theresa Point, Manitoba, there is currently an active outage due to power issue.
https://www.telus.com/en/mb/outages
02-22-2024 09:29 PM
02-22-2024 09:28 PM - edited 02-22-2024 09:29 PM
Does SMS texting work?
Try rebooting device, resetting network connections, and toggling airplane mode on/off.
When you dial 611, does it state service is active or suspended?
You may need to pay to get another cycle?
Could also be network outage in your area?
To contact a Customer Support Agent, send a private message to them by clicking here. You’ll need to be logged into your Community account for the link to work.
Watch for their response in your Community private mailbox which will be indicated by a number on the small envelope icon to the left of your Community avatar, or tap your Avatar down in Messages.
