02-22-2024 08:58 PM - last edited on 02-22-2024 09:00 PM by computergeek541
I purchased the 15 day US add on plan - used all my data before heading home so I added an ala carte 3 GB which has been charged to my credit card and shows up on my account however I am not able to use the data. It’s as if I am not connected. I tried turning my phone off and back on - double checked that I’m connected with t mobile etc. help.
02-22-2024 09:08 PM
self solution removed
02-22-2024 09:08 PM
I think I figured it out. Since all hell was breaking loose on a long car ride I added the Canada add on instead of the US add on…. Now I have to figure out how to get this switched.
02-22-2024 09:02 PM - edited 02-22-2024 09:04 PM
@Ohnokiki wrote:I purchased the 15 day US add on plan - used all my data before heading home so I added an ala carte 3 GB which has been charged to my credit card and shows up on my account however I am not able to use the data. It’s as if I am not connected. I tried turning my phone off and back on - double checked that I’m connected with t mobile etc. help.
Are you trying to use that data in Canada? The 3GB US data roaming add-on can only be used in the US. Also, was the 3GB data add-on that you purchased have a price of $25 or was it $30?
