11-16-2023 06:24 PM
I currently have the old public rewards plan (not public points).
How does the community reward system work? Is there a breakdown of when you earn $1 of rewards for community?
11-16-2023 06:39 PM
The standard Rewards $ credit are:
- $2/month for using AutoPay
- $1/month for every year you are with PM
- $1/month/each family and friends referral
On top of that, you will receive $1/$2/$5/$10/$15 credit on this Community involvement depending on how many Bravos you receive and how many solved solutions you receive…basically quit your daytime job or on pension to be on this Community. 😉
Only members with Oracle status will receive $20/month credit.
PM staff have a secret formula on how much you receive for your involvement.
11-16-2023 06:38 PM - edited 11-16-2023 06:40 PM
it’s both very complicated and very straightforward.
It is a combination of bravos received, numbers of posts, and numbers of solutions being accepted as yours.
If you spend 5 to 10 minutes a day for the month you might get a dollar.
If you spend upwards of 2 to 3 hours a day you might get as much as $15 a month.
Anywhere in between, and you might get anywhere from $2 to $10 a month.
Basically, it’s about providing relevant, precise, and informative answers.
Other than that, it has been said that you will do better off collecting refundable from the roadside for the time spent versus the time spent here for rewards.
11-16-2023 06:36 PM
By participating , reading and helping others with questions . And learning and sharing and good things will happen
ranked chart here
11-16-2023 06:30 PM
hi @Fatfin
no definite rule how to earn the different level of rewards, $1/2/5/10/15
it is a secret formula with PM, but just reply anything you have an answer
