Plans switch
Teresy80046
I have a plan with the old rewards. If I switch to the Black Friday promotion would I keep my $6 a month discount?
@Fatfin  It does cap at 5 that’s on 90 day plan so you see the $4 x3 to make $12
Fatfin
wow how did you get loyalty of $12 off? I thought it caps at 5 after 5 years.
Fatfin
Yes
hi @Teresy80046 yes, you will get to keep the old rewards and will still have the $6 rewards
@Teresy80046  YES you will keep your old rewards there tied to your account not your plan so go ahead and change to whatever plan you like best
