Community - Reply Problem?
Anyone has issue with replying post this morning ?  Tried to reply issue, clicked POST, it keep spinning.
Glad I didn't re-post or refresh.  I went back and check the main page and noticed that my reply in fact was posted (but the other windows which I was used to type the reply and post is still spinning and spinning  )
20 REPLIES 20
@hTideGnow wrote:
Yes, I think it is back to normal for me as well.  I can post/reply, notification works.
@hTideGnow  - Yes, The Community Site had a rough go at the morning. Mine was spinning too. And a couple times I had duplicate posts but didn't know there were two until I went back to the thread.
Nutty!
It all passed though. 😁
Happy Communitying !
.. my Notification is now working too.
@Anonymous
 Mine seems back to normal and all my posted messages have disappeared ftom my drafts.
Maybe the ole beater needs a new battery - booster cables were just enough to get er to the shop.
Wasn't there supposed to be an "overhaul" happening to the Community site?
@darlicious wrote:
But the reply seems to be working normal again.
I thought mine were working fine earlier too but then they weren't.
Except posts/threads are not showing up as read though....they remain in bold.
@darlicious wrote:
@hTideGnow
Hey I just got notified you mentioned me! Things are looking up!
Go to your profile and scroll down to about the middle and you will see them on the right hand side. Your unfinished posts will appear here unless you get the dreaded red warning message.....they don't save those ones.....
The booster cables must have worked on the Community site.   🤣🤣🤣
@darlicious , so at least notification is working for you now  😀  not  me yet
@hTideGnow
@hTideGnow
Click your avatar, then My profile.
If there's anything in "draft" form, it'll be to the right.
You'll have the option to re-enter the draft and complete it, or delete it from that page.
@darlicious , there is a Draft box?  How do i access draft?
I'm getting a myriad of issues from this on top of it not "sending".....
  1. No notifications.
  2. My posts don't show up on the landing page.
  3. When I hit reply to a new message it goes back to the reply that is still trying to send even though it has posted in the thread.
  4. All of my replies are piling up in my drafts.
benfatto
Seems ok now?
.. same for me.  Also,  I checked my own last posts, doesn't seems to update.  Just act funny the whole morning..
Yes, it's producing odd results when posting/ replying.
Error 504, Cloudfront errors...
Issue with replying for the last couple of hours.  If you post, it was just spin and stall.  I just close that window and start another page.  The post goes through.  Try not to repost otherwise you will get multiple posts like what happened earlier.
@hTideGnow
Same here....I think it just needs COFFEE!
@ShawnC13 wrote:
Yeah it seems like the community is having some issues this morning.  Maybe stayed up to late on a Friday night
@ShawnC13 , you meant DRUNK!!!? 🤣
ShawnC13
