Community Points
lovelyrachel
What is the best way to earn Community Points? What do you like to spend your points on?
10 REPLIES 10
Public506
Honestly, I’m angling for the bonus points too.
I’ll probably use all of mine for $15 bill credits, but also, I do like the idea of parting with a point or two, if I can hopefully win a gift card at some point. It’s just refreshing to see a set up that is more transparent and straight forward than some other (unnamed) companies.
@lovelyrachel wrote:
alright, thank you @will13am . It is kind of fun, like a game seeing those notifications pop up. But I will temper the monetary reward aspect 🙂
@lovelyrachel    Unfortunately (or fortunately) the fun aspect of seeing those notifications pop up will soon wear off and you'll probably want to turn most of them off before long except, perhaps, for receiving a tag, bravo or solution notification while logged into the community forum site.
Welcome to the Community and hopefully you'll enjoy learning and helping others.
lovelyrachel
thanks @Meow
lovelyrachel
thank you @hTideGnow
lovelyrachel
Lux
Buying 1GB data add-on with points (10 points) is better than spending $15 on 1GB, so if you want some extra data, I would go with that.
will13am
@lovelyrachel , fair warning, the community help thing is a labor of love more than it is a money/point making machine.  If you have time, by all means provide a helping hand where you can.  Just temper the enthusiasm that this is a monetary reward.
@hTideGnow wrote:
Hi @lovelyrachel
best way to earn Community points?  Come here daily,  stat unstand PM netowrk more, and reply if you cam help.
Can you teach me that skill?! 🤣😂😋
Hi @lovelyrachel
best way to earn Community points?  Come here daily,  and understand PM netowrk more, and reply if you cam help.
How to spent the point?  If you are on Public points  if you need to buy add-ons, use it
  If you don't need extra add-ons, of course best is to redeem for $15
Meow
Best way to earn points is to Help others.
As for spending it is up to you. If I had points I would spend them to reduce bill.
