02-22-2019 10:22 AM - edited 01-05-2022 03:26 AM
Restarting Samsung Galaxy Phone Codes
1 #*2562#
2 #*3849#
3 #*3851#
4 #*3876#
(These are all the Samsung Galaxy codes to restart your android without manually doing so.)
System Control Codes
1 *#7284# USB I2C Mode Controlling Panel
2 *#872564# This code controls the USB Logging
3 *#4238378# This code controls GCF Configuration
4 *#0283# This code controls Audio Loopback
5 *#1575# Manage and control GPS Menu
Phone Information Codes
1 *#*#4636#*#* This is the code for your phone information
2 *#*#4986*2650468#*#* This code is used to View Phone’s PDA , H/W, RFCallDate details
3 *#*#1234#*#* View PDA type and Version
4 *#*#1111#*#* code to display Firmware software version
5 *#*#2222#*#* code to display firmware hardware version
6 *#*#44336#*#* Display your build version ROM sales code, build time and change list number
7 *#272*IMEI# Use this code to change your sales codes and reset the user data
8 *#0011# This code is used to show the status information for Your GSM Network
9 *#*#4636#*#* Display all the user statistics from the beginning of time and the essential Phone Information
10 *#12580*369# this code checks software and hardware information.
11 *#12580*369# Display all Software and Hardware information of your phone
12 #*#8377466#*# Display all Software Version and Hardware Version information for your Android device
Codes for all testing purposes
1 #0589# This Code is used to enter Light Sensor Test Mode
2 #0588# Proximity Sensor code
3 #*#526#*#* Enter WLAN network by using this code
4 #*#232338#*#* This code will display all WIFI mac address
5 #*#1472365#*#* Using this code to Test GPS
6 #*#1575#*#* A next GPS test code
7 #*#232331#*#* Troubleshoot your Bluetooth
8 #9090# Diagnostic Configuration code
9 #*3888# BLUETOOTH Test mode code
10 #*#0*#*#* Test Your LCD Screen
11 #*#0673#*#* melody and audio Test
12 #*#0842#*#* General Test Mode (vibration test and backlight test)
13 #*#2663#*#* Test your LCD touch screen
14 #8999*8378# Universal Test Menu
15 #0842# Vibration Motor Test Mode Code
16 #0782# Test your Time in real time mode
17 #0673# Audible Test
18 #0*# General Test Mode function
Network Codes
1 *7465625*638*# This code gives you the ability to customize Network Lock MCC/MNC
2 #7465625*638*# Use this code to perform Network data locks and (Insert Network Lock)
3 *7465625*782*# Customize your Network Lock NSP
4 #7465625*782*# input any semi- Partiality Network Lock Keycode
5 *7465625*77*# Key code for Network lock SP
6 #7465625*77*# key to insert network operator
7 *7465625*27*# code for Network lock and operation for NSP/CP
8 #7465625*27*# phone code for Content Provider network insertion
9 *#272*IMEI# this code gives you the buyer code
10 *#2263# RF Band -select your network mode type
Firmware and Service Mode Codes
1 *#32489# Enter Service mode (Ciphering Info)
2 *#197328640# This is the code for default Service Mode
3 #0808# usb service
4 *#9090# service mode usb
5 *#2663# TSP / TSK firmware update
6 *#34971539# Update your camera firmware
7 *#526# WLAN Engineering service mode
8 *#528# WLAN Engineering service Mode
9 *#7412365# Enter your Camera Firmware Menu.
10 *#8736364# OTA Update Menu screen code for android
11 *2767*4387264636# Sellout SMS / PCODE view
Codes for Factory reset (Android)
1 *#7780# Factory Reset all your phones with a confirmation message
2 *2767*3855# Full factory reset without a confirmation message. It will perform a hard reset.
3 *#*#273283*255*663282*#*#* copy files and backup media files
Codes for Debugging
1 #745# Dump Menu for dumping RIL
2 #746# general Debug Dump Menu
3 #9900# Bring up your System Dump menu, give you the option to boost your network speed, Wi-Fi and battery
4 #03# NAND Flash S/N
5 #7594# Remap Shutdown to End Call TSK
6 #272886# Auto Answer Selection
02-22-2019 10:38 AM
@Greg45 This is helpful material for someone. Good post.
For me I never remember any of them working in my life except the one to bring up the imei number.
I thought I would give it a shot as its been a while and picked a few but no dice.
"USSD Code running..."
.......then a few seconds later.......
"connection problem or invaliid MMI code"
02-22-2019 10:26 AM
@Greg45, this is a great resource for those using Samsung phones!
