09-11-2022 04:42 PM
09-11-2022 07:20 PM
09-11-2022 05:07 PM
lol gotta love it
also @teckfuture just take heed of the advice to remove your payment card regardless of whether you port out or let it go into inactive for 90 days so that it cannot be charged in error. Some people have had issues with that and then have to jump through the usual hoops for a refund
09-11-2022 04:56 PM
Hi @Alexandf While the remove CC part was correct, you are here long enough , with different usernames , you should know CS Agent cannot help to "also to closed account."
09-11-2022 04:51 PM
send private message PM support CS_Agent at: ask them to remove your credit card.also to closed account.
(envelope icon on the top right) CS_Agent will reply you there.
09-11-2022 04:45 PM
@teckfuture Easiest way is to port out your number to another carrier which closes your account. Also you can disable autopay or put the account into lost/stolen mode and after 90 days of account being suspended due to lack of payment, it will close permanently and you will lose the number as well.
If you need to remove the payment card, then you need CSA's assistance to do that, so submit a ticket via chatbot here: https://widget.telus.tiia.ai/publicmobile/publicmobile.html
09-11-2022 04:44 PM
@teckfuture - or, if you port your number with public out to another provider that also closes your account here with Public.
09-11-2022 04:43 PM
@teckfuture you can first disable Pre-Authorized payments. PM wont be able to renew when the time comes, your account will then be suspended. 90 more days, it will be closed permanently
