Clarification re: unlimited international texts
03-06-2020 06:10 AM - edited 01-05-2022 09:48 AM
It says "Unlimited International Text and Picture Messaging" so does that mean video is not included? Also, does this mean I can send and receive texts from any area and country code at all and it is included?
Joining Public
03-06-2020 05:16 PM
@helenhelen, chances are you will probably need to make sure your data is turned on to send the videos too. If possible use one of the many apps the person said below, or maybe use Messenger or WhatsApp, and send the video that way over a wi-fi connection at any hotspot that you can grab if you are travelling internationally?
03-06-2020 09:25 AM
You could use apps like vine, snapchat, or Instagram to send videos
03-06-2020 09:06 AM
@helenhelen wrote:It says "Unlimited International Text and Picture Messaging" so does that mean video is not included? Also, does this mean I can send and receive texts from any area and country code at all and it is included?
Yes. I did try international text send and received , but I didn't try sent video.
Make sure you are in Canada when you sent international text and video, otherwise it won't work.
03-06-2020 08:41 AM
@jor123 wrote:Compression is brutal on video MMS though.
Yes the videos have to be very VERY short and low quality. I noticed that Rogers/Fido/chatr can't receive most.
03-06-2020 08:27 AM
03-06-2020 06:36 AM
To add to what @Triguy said, from within Canada.
03-06-2020 06:26 AM
Yes, you can send mms messages to any country including short videos.
