02-25-2024 01:14 AM - last edited on 02-26-2024 12:15 AM by Dunkman
Hi community,
I have to change my current iphone 6 because I can’t use the photos and sms…public mobile will not support it. I was thinking of switching to a Google pixel 8 an android phone. How easy is it to switch to another phone from iOS to android.? Who do I contact to do the switch?
02-25-2024 12:19 PM
@DennyCrane There's an article about it here
https://www.publicmobile.ca/en/on/get-help/articles/picture-messaging-updates
02-25-2024 11:22 AM
@Phil_Adelphus good to know - thanks. I wasn't aware an update happened.
02-25-2024 11:20 AM - edited 02-25-2024 11:21 AM
@DennyCrane The iPhone 6 is not supported by the recent Telus change in MMS, the oldest is iPhone 8 on ios 16 and newer. So if the problem is MMS, which it sounds like, then a new phone would be the only option if @Catbear needs MMS due to contacts having Android phones. I think that's probably what @Catbear meant since SMS would still work and not be affected by the change to MMS
02-25-2024 11:05 AM
MMS should work on your iPhone 6. It's probably an APN settings that need to be fixed.
That said, that's a very old phone that cannot use VoLTE, so it's probably a good time to upgrade if you have that option. Pixel 8 is a great phone.
02-25-2024 07:03 AM
@Catbear iphone 6 because I can’t use the photos and sms…public mobile will not support i
I thought there were people on here who use iPhone 6, what info did you get that PM doesn't support pictures and SMS, or do you mean MMS?
02-25-2024 01:25 AM
It will be a short learning curve. Androids are more customizable than iPhones.
I have both...iPhone 14 Pro Max and the Samsung S24...love both. My everyday user is the iPhone 14 PM because iPhones was my company phone and is familiar with all the functions. Before the iPhone, it was the Blackberry.
02-25-2024 01:16 AM
Welcome to the Android World!!
shouldn't be hard, just follow the steps
