12-25-2022 12:55 PM - edited 12-25-2022 12:56 PM
Currently I am on $30 2GB data at 3G Speed plan with auto pay and loyalty bonuses.
- • 30-day plan
- • Unlimited Canada-wide Talk
- • Unlimited International Text
If I change this plan, to either $30 3GB data at 3G Speed or $35 3GB data at 4G Speed, will it covert my benefits to points or I can still continue to have loyalty and autopay $$
Plans
12-25-2022 01:08 PM
HI @Noreenmukhtar you can change plan and not worry being changed to the new rewards.
You will have to join yourself to the new rewards, you won't just get moved over to the new rewards because you changed plan
So, no worry, just change to the new plan you want and you will get to keep all the Autopay bonus and Loyalty rewards as usual
12-25-2022 01:04 PM
When you switch to whichever plan, you won't lose any of your current rewards and such, since they are attached to your account and not the plan that you have.
Just make sure that you schedule your change of plan on your next renewal date, so you won't forfeit anything from your current plan.
12-25-2022 01:01 PM
Your rewards are tied up with your account, not plan so you can change to whatever plan you want without losing them.
12-25-2022 12:59 PM
DO NOT join the new Rewards Public Points
You can make change to your plan but do not join Public Points
Main things to loss, $2 Autopay and the Loyalty reward!!
you can make better rewards instead of Autopay if you have plan $40 and above
And there is no way to get more for Loyalty rewards on the new Public Points. New Public Points only gives you 10 points ($10) every year. Loyalty rewards can get you $12 , $25 and up to $60 per year!!!
12-25-2022 12:58 PM
@Noreenmukhtar @You have to manually choose to go to point system , otherwise you keep your loyalty rewards and I think there better myself then the new point system
12-25-2022 12:56 PM
@Noreenmukhtar @No you will not loose your rewards , you in fact get to keep them . Rewards are tied to your account not your plan
