02-24-2022 10:08 AM
I currently have a number with Public Mobil that is no longer in use and can be deleted. I also have 2 cell phones currently on Telus that I would like to switch to Public Mobil if the pricing works out. What are the pricing packages available for adding 2 phones?
02-24-2022 10:28 AM
There is no advertised promotion at the present time. There is no extra discount for adding two lines, except for using first line to refer the 2nd line. The 2nd line will get $10 credit within 72 hours. The 1st line will get one reward point/month (equivalent to $1) as long as 2nd line is active with PM.
There is this promo code: 2GBBONUS for plans greater then $35/month
Not advertised, but has been active since spring of last year. YMMV.
You may want to consider keeping the your present PM line active and just port one of your Telus lines over to original PM account. That way, you keep your old PM rewards (better then the PM reward points system). Then use this line as referral for your 2nd Telus number.
02-24-2022 10:24 AM
PM has no family packages nor discounts for multiple accounts. Prices are per account. And you would need unique email accounts per each PM account.
PM account not in use can be closed if you remove autopay. After next renewal it will be suspended due to no pay and deleted after 90 days again for no pay.
02-24-2022 10:22 AM
@Farmerjeff : If you have that PM SIM in a phone then try dialing 611 and see what you get. If it wants money then I would recommend you keep that account and transfer one of your Telus numbers into it.
Just for clarity, it's not the phone...it's the SIM attached to an account.
02-24-2022 10:18 AM
@Farmerjeff If you had an old Public Mobile account no longer in use. After 90 days of non payment the account is closed and wtv number on it is gone.
To join. You need a new sim per phone. One sim per account per email address. You can't have two phones on one account.
Plans are at link below.
https://publicmobile.ca/en/on/plans#plans-start
If you have a friend or family member on Public Mobile be sure to ask them for their referral code for the first account you sign up to PM. You'll get a $10 signup credit. Once the first account is created use the referral code on the new account for the second account.
