09-08-2018 11:22 AM - edited 01-05-2022 01:42 AM
09-10-2018 12:23 PM
09-09-2018 05:14 PM
@GeorgiaJack wrote:Yes, old plan had data, new plan has data.
Different day, same drill unfortunately.
If rebooting your phone does not help, click this: message to moderators to send a private message to the moderator team with a description of your issue along with your phone number and 4 digit PIN. If you’ve forgotten the PIN, provide any 3 of the following in your message: complete mailing address, email address, alternate phone number, last top up date & amount.
Moderator hours are: Monday to Friday, 9 am (ET) to 9 pm (ET); Saturday - Sunday 9 am (ET) - 7:30 pm (ET). Usually they answer within in a few hours, but can take 24.
Meanwhile, if you need to make phone calls try an application like that from fongo.com. It provides free calling across Canada from wherever you are connected to wifi (or on cellular data).
09-09-2018 04:55 PM
09-09-2018 02:46 PM
@GeorgiaJack wrote:Yes it was.
@GeorgiaJack did your previous plan include data?
Also: data roaming does not need to be on (unless you plan to travel to the USA with a US Roaming data add-on).
09-08-2018 12:30 PM
If the moderators seemingly broke everything during the plan change you might need to contact them again and explain what happened. Hopefully they will fix whatever is wrong quickly.
09-08-2018 11:57 AM
Yes it was.
09-08-2018 11:38 AM
Was everything working prior to the plan change?
