11-25-2024
08:21 PM
11-25-2024
10:32 PM
computergeek541
I just switched to PM. I brought my old # with me. I can't receive texts or calls. I can't send texts
11-25-2024 10:30 PM
contact customer service agent to fix your issue. Either via the following link:
If you are having a difficult time, then you can private message CSA:
Send a private message to CSA through the following link :
11-25-2024 09:25 PM
you cannot send texts, but can you make calls? does data work? If neither, than it is not problem with the port but problem with the activation. You need PM to help, and you need to message them (since you probably cannot login My Account and open Chatbot ticket). Message PM here:
11-25-2024 08:23 PM - edited 11-25-2024 08:24 PM
did you download the free Public Mobile app to activate your new accou8nt, as required.
Did you reply YES to port request ?
