09-08-2020 11:17 AM - edited 01-05-2022 03:49 PM
I changed my plan and made the $25 payment but I'm not sure why my phone is still not going.
09-08-2020 04:11 PM
@hairbag1 wrote:Recently, (April) the wife downgraded to the $15 plan from $25 plan and had to contact moderator to make that change. The self-serve tool was not going to allow the change. The moderators facilitated the change in about 30 minutes.
Did the exact same downgrade in April/May, had no issues. Might have been something specific to your account.
09-08-2020 12:11 PM
one thing I've learned since being here, you can either rely on an unreliable system. or you can make it reliable on your own.
the biggest issue I've found, is the flawed, two step process pm uses.
anytime one wants to make plan changes, add-ons etc. the best thing to do is add funds manually to remove the broken link in the chain
09-08-2020 11:56 AM
I've downgraded my plan a few times since i started w/ PM...no issues. Transient issues occur.
09-08-2020 11:34 AM
@hairbag1 Thanks for the update. In this case, @bryanphilip mentioned that he was able to make the change so it might not be the same issue. If downgrading was a system wide problem I would assume an announcement would have been made. But then again.....
09-08-2020 11:29 AM - edited 09-08-2020 11:29 AM
09-08-2020 11:26 AM
@bryanphilip wrote:How do I get a hold of a moderator?
@bryanphilip Did you restart your phone? When you dial 611 is your account suspended?
To submit a ticket to the Moderator Team, please start a conversation with the Public's virtual assistant, SIMon by clicking here or the icon (bottom right of your screen).
If you are still having problems contacting Public Mobile then click here. The link sends you to the private message function and adds the moderator team as recipient for a private message. You just have to enter a title and text in the body of the message describing the problem and post. The message will be received by the moderator team and they will respond to it. You will receive the response in your private message inbox.
09-08-2020 11:24 AM
@hairbag1 wrote:
@bryanphilip wrote:I changed my plan and made the $25 payment but I'm not sure why my phone is still not going.
To downgrade your regular plan you need help from a moderator.
@hairbag1 Since when?
09-08-2020 11:22 AM
09-08-2020 11:20 AM
@bryanphilip When changing plan you have two options. Immediate change and change on next renewal. Which one did you select?
09-08-2020 11:20 AM
hi if you see a reactivate button in your account press it
09-08-2020 11:19 AM - edited 09-08-2020 11:21 AM
09-08-2020 11:19 AM
@bryanphilip Does your self serve show a balance of 25$ ?
