forgot password and security question answer
suzq
how can I log in to update credit card
RossN
@suzq hello if you forgot your password  contact a moderator  click on the ? Bottom right hand corner Ask Simon to speak to a human this will help create a ticket to speak to a moderator mention password reset   check the envelope top right corner for a reply response time is 2 to 48 hours
Helpershelper
@suzq
Give the mods a message and they will help you out with this.
Once you log back in, paste this link and scroll to the bottom to update card:
https://selfserve.publicmobile.ca/Overview/payment/Make-a-Payment/
