10-24-2021 03:57 PM - edited 01-06-2022 03:52 AM
10-24-2021 05:28 PM
Well that's a bit of a mess! Whatever the fourth number you chose is what you are likely stuck with. Look under the "Your plan" section to see what number is listed on your account. If none of the suggestions get your service working then customer support will have to fix the issue.
10-24-2021 04:35 PM - edited 10-24-2021 04:36 PM
Changing Your Number
You can change your phone number up to 4 times every 30 days after you’ve activated. To change go to your Self Serve Account here link, and:
and do Rebooting your phone
*what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
**you can try reseat the SIM card and Make sure your phone is off before removing your SIM card,
1. power off your device
2. take out the SIM card,
3. waiting a 1 minute,
4. put it back and power on,
5. toggling airplane mode off/on,
Go to Settings > General > Reset > Reset Network Settings.
This also resets Wi-Fi networks and passwords,
or visit Here link,
click Here link,
or visit Here link,
and go Changing APN Settings On Android device
click Here link,
Ensure you have the correct APN settings by visit Here link,
and try manually selecting network "3G ONLY" or WCDMA only,
for iPhone visit Here link
or Here link
for android visit Here link ,
and do again Rebooting your phone
and if still not fix it please you Have To Submit a Ticket To Contact Customer Support Agent by CS_Agent ,and Explain your issue to they can solve your issue, they are nice service Team the will help you 100%.
Here’s how to contact Customer Support Agent by CS_Agent,
Good Luck.
10-24-2021 04:09 PM
What happens when you call the last PM number that you choose? Is that number still active? What number shows up in your self service account?
Maybe reboot your phone? Network reset of phone?
10-24-2021 04:06 PM - edited 10-24-2021 04:09 PM
@FaithOrton_ wrote:yeah i did it more than a few times what do I do now is there anyway to fix it
@FaithOrton_ You need to contact customer support by clicking the chatbot bubble bottom right of screen and submit ticket for help, or click the envelope icon top right next to your avatar and send a private message to CS_Agent for help.
Edit: Here's a couple of links to the chatbot and private message customer support: https://widget.telus.tiia.ai/publicmobile/publicmobile.html
10-24-2021 04:04 PM
10-24-2021 04:02 PM - edited 10-28-2021 10:32 PM
@FaithOrton_ wrote:I changed my number a few times and now nothing is working.. no one can call my new number I cant call numbers or a voicemail it says its not in service what do I do
@FaithOrton_ When you say you changed your number a few times, was it more than 4 times within 30 days, as that is the limit for changing numbers?
Edit: Perhaps try rebooting your phone, or powering off and removing SIM and reinsert after a couple of mins and restart phone.
