Change plan
Aaron_munroe
Like to change plan but keep my data promotion
2 REPLIES 2
Terryscell
Upgrade or same is ok. Downgrade loses bonus.
I recently changed plans, to one at exactly the same price, and kept my bonus.
hi @Aaron_munroe
if you meant the loyalty data add-on which 150 days expiration, you will lose it if you downgrade you plan.  Upgrade is ok
