07-03-2019 08:12 PM - edited 01-05-2022 05:42 AM
09-18-2019 11:44 AM - edited 09-18-2019 11:48 AM
I just changed my number from XXX to YYY but as of now both the numbers are not working, when i call up older number, i hear the tone that shows phone's ringing but the Real Phone is not ringing (i am just hearing that tone), when i dial the newer number it says UM2 this is not a valid number and then magically i again hear the ringing-tone which falsely shows phones ringing but again the Real Phone does not ring. kind of fools people to think the phones ringing and this dude is not picking up, when actually there is no Real Phone Ring...
So as of now i have no working number, it been about 45 minutes... too long 45 minutes
When i change the number i should atleast get warning that this might take some time...
09-01-2019 11:38 AM
09-01-2019 11:31 AM
@Awesme444 click here, expect up to 48 hours for a reply! Could be sooner! You can keep using your Koodo Sim until the port is complete.
09-01-2019 11:30 AM
Send a private message to moderator through the following link :
09-01-2019 11:29 AM
It’s Koodo how do I reach moderator team
09-01-2019 11:21 AM
@Awesme444 so you're trying to port a number? From which carrier? If it's Koodo prepaid you'll have to message the moderator_team, if it's any other you should be able to do it in the self serve
09-01-2019 11:21 AM
@Awesme444 wrote:It says unable to transfer number
If you're coming from Koodo prepaid then you'll need moderator assistance. The source also needs to be active.
09-01-2019 11:17 AM
09-01-2019 11:00 AM
@Awesme444 it should be when you log in to your self serve account on the right of the page it says change number
09-01-2019 10:56 AM
Change phone number not under my profile
07-05-2019 04:28 PM
Hi Amanda,
I'm really sorry to hear that you are experiencing this issue, but we can surely help you find a solution
In order to do so, can you send us a private message via the Community? Please click on this link: https://goo.gl/JnHqMR
Remember that you need to be logged in your Community account, to be able to send a message. If you are still not registered, you can click here https://goo.gl/7Z88Sb and go to "Sign in" then on "New User? Register here."
Sincerely,
Public Mobile Team.
07-05-2019 08:53 AM
@AmandaBrooke wrote:I desperately need to change my number (to avoid a stalker)...and I’m not able to sign in to my account! My email was originally entered with a spelling mistake so it doesn’t exist and I don’t have the password for that... What is the fastest way to get the help in the private messages? From what I understand there’s nothing anyone can do otherwise.
I would hope "Amanda Brooke" is a fake name you're using for this forum, if you're really being stalked!
07-04-2019 05:17 PM - edited 07-04-2019 05:21 PM
@AmandaBrooke, i've merged these two threads together as they are both about trying to change your phone number.
Using an incorrect e-mail address shouldn't prevent you from logging in, and the password would be the same as when it was set up, although you wouldn't be able do a password reset.
You'll need to contact Moderator_Team as mentioned earlier to correct the e-mail address and to restore account access. You'll have to go through some steps to prove to them that this is your account.
07-04-2019 01:59 PM
@AmandaBrooke wrote:Lol thanks.. it’s said to ask questions for points , so I did 🤷🏼♀️
@AmandaBrooke also, pro-top: don't tell people you're posting for the rewards. It's definitely frowned upon.
07-04-2019 01:32 PM
07-04-2019 01:29 PM
07-04-2019 01:12 PM
I def. did not mean to assign my post as a solution. @RossN had the solution. Thx for correcting. 👌🏼✅
07-04-2019 04:12 AM - edited 07-04-2019 04:24 AM
Please don't mark your own messages as solutions. I've reassigned the solution to the person who answered your question. You'll also find that it's much appreciated when members focus on the quality of content posted.
07-03-2019 08:18 PM
@AmandaBrooke No prob ![]()
07-03-2019 08:17 PM
07-03-2019 08:14 PM - edited 07-03-2019 08:17 PM
@AmandaBrooke you go into your account and pick change number directly under my profile
