Change number
Sassybella
I cannot chane my number its gives me an error message it say its failed n I really want me number to be changed
@Sassybella
i suggest you can try it for a different Browser
and clear cache and cookies for any Browser,
and use a Browser from your computer,
and just make sure your Browser is up to date update
sometime is the Browser is not update is give a issue.
and Restart your computer, is will help.
and if you use a home internet please do one thing take it your power internet for about a minute and put it back,
How To Changing Your Number
You can change your phone number up to 4 times every 30 days after you’ve activated. To change or transfer your number after activation, go to your Self Serve Account here and:
  • Select the “Plans and Add ons” tab
  • Click on “Change Phone Number”
  • Then, you can choose to select a new phone number or to transfer a wireless or wireline number from another provider.
You will need to provide the same information as requested during the activation process above.Your previous service provider may also send an SMS text to validate the transfer, so ensure your old SIM card is still in your device so you can receive and respond to this message. Please do not replace your old SIM card with your Public SIM until the number has been successfully transferred.
@Dtack @Triguy
esjliv has correctly stated that the number change limit is 4 times per 30 days.
mh1983
@Dtack wrote:
@Sassybella
Sign into self serve.
Under My Profile, you'll see a Change Number option - bottom right.
You can do this once per 30 days.
I think the OP is already aware of this option and was saying it didn't work (produced an error message).
Dtack
@Sassybella
Triguy
Here is a previous thread.  You can change your phone number once every 30 days.
https://productioncommunity.publicmobile.ca/t5/Self-Serve/Change-my-phone-number/m-p/647535#M50443
Hello @Sassybella ,
Try:
  • Log out of your account.
  • Clear your browser's history, or try a different browser / device.
  • Also, you can try opening a tab in incognito mode, as this helps with finicky websites.
You can change your number 4 times every 30 days if you wish. So this should work for you.
