Change my email
AngeIngabire99
I reset my password ,but i cannot sign in .so i would to change my email to see if it can work
gpixel
@AngeIngabire99
the important step after resetting the password is to login using an incognito or private tab
@AngeIngabire99 @To change your email you need supports help with this
  • Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to our Agents. Click here
  • you can send a private message to our  CS_Agents by clicking here.
HALIMACS
@AngeIngabire99
Logging in issues is common with Public Mobile’s website, which displays outdated information.  To deal with this:
  • Try clearing cache and cookies and opening an incognito tab
  • Try using a completely different browser from a completely different device which does not have stored/remembered credentials
  • If using a device with stored/remembered credentials on Chrome browser, sometimes when these autofill, the device also attempts to automatically log you in.  If a device does this, do not tap the sign in button while it is trying to log you in as it will deliver an error message
dabr
@AngeIngabire99   Only customer support can change the email on account for you so submit a ticket via chatbot here:  https://www.publicmobile.ca/get-help
edit:  BTW, are you trying to login using incognito/private mode as there are caching issues with PM's website?
