07-20-2023 12:41 PM
Hello I followed all the instructions to change my home adress, I really need to do it but it doesn't change, it says invalid, I have tried just with postal code, with the city, the street, all the combinations and it doesn't work. I don't like public mobile since you can't do anything. Everything send error and we're paying, it's not free. Very bad service. If I can't solve this problem I'll finish this cicle and I hope I can cancel my plan.
07-30-2023 04:23 PM
I suppose @Luddite, if they're able to get a hold of someone at public mobile for that information 🤔
I believe Emergency Services method of locating a person is more available, reliable, and prompt.
My reply was moreso toward wondering why it was so important to the OP - I wonder if there was another reason?
07-30-2023 03:34 PM
@dust2dust wrote:@Luddite- Address would be used for landline (whether copper, fibre, cable, cell base-unit) and fixed, non-mobile voip services. 911 will ask your location on a cellphone. They can do some triangulation and if you have your gps on. It's not accurate. But otherwise not. As far as I understand currently anyway 🙂
I can't confirm this, but it wouldn't make sense that they wouldn't have access to the address saved on the Public Mobile account. As for emergency services asking for your location when calling from a cell phone, they will also ask if someone calls from a POTS (or VoIP) landline.
07-30-2023 03:01 PM
07-30-2023 02:56 PM
@HALIMACS May be important to some people if they need 911 to locate their home address. VoIP services regularly remind customers to keep home address updated for that reason.
07-20-2023 07:44 PM
Why is it so important for you to change your address - it means nothing toward the service here.
Indeed, it's strange there's even a field for it since any user can put ANTHING they want in those fields as they are not confirmed nor checked nor verified in any way.
07-20-2023 12:48 PM
Yes the address is an autofill. Build it out until it finds you. I don't think the space between unit and street is correct. I think there's no space. Street directions can be tricky. Try different variations. But let it find you as you add more.
07-20-2023 12:43 PM
@Catag0 wrote:Hello I followed all the instructions to change my home adress, I really need to do it but it doesn't change, it says invalid, I have tried just with postal code, with the city, the street, all the combinations and it doesn't work. I don't like public mobile since you can't do anything. Everything send error and we're paying, it's not free. Very bad service. If I can't solve this problem I'll finish this cicle and I hope I can cancel my plan.
did you try to just type in partial address and let the lookup finish it for you?
And if you are living in apartment, the format should be 101 - 123 ABC Street
https://myaccount.publicmobile.ca/en/account/edit/account-info
Worst case, message support and see if they can manually change it for you
07-20-2023 12:41 PM
HI @Catag0
the address is not really useful, this is prepaid provider and cannot be used to proof for govt anyway
