3 hours ago
I ported over my number from another provider, however when I log in it still goes to the old number I do not have access to. Is it possible to change Verification number to my current one and make sure the connection is fully severed?
56m ago
Aren’t you porting your old number to PM but port a number that you don’t have accessing to? Confusing!
Can you clarify your issue?
3 hours ago
Hello @Dhjrfjfjrofk
This means your old service providers SIM is still working. There is a number to call to have this fixed. Please look up in the top right corner mailbox for hte number.
3 hours ago
hi @Dhjrfjfjrofk are you receiving any inbound calls? did you reply yes to a text from your old carrier to approve the port?
not sure if your port is completed, check with PM porting support team and confirm. I will send you the number to PM Porting support team Please check your community inbox
