Password
N5
I notice trying to change password at time you get an email, then public mobile sends a code to same email if you are on the phone, and try to get the code, you no longer can enter code in email you just got off of, so I suggest public mobile to send the code to phone number to stop the need for two devices. It's just a suggestion if others have noticed that issue as well.
1 REPLY 1
hi @N5
no sure why you need two phones to change password.  you can switch app on the phone easily.  PM app to email app to get the code and back to PM app to enter the code.  Now sure what the issue you were facing
