03-25-2019 10:59 AM - edited 01-05-2022 03:55 AM
I am an exisiting customer and would like to change my plan, my next billing date is March 27/28, 2019. If I change my plan today, will PM start my "new" plan today or Mar 27/28 after my old plan expires?
03-25-2019 11:12 AM
Thank you Everyone for your prompt reply.
Thanks for the tip on choosing "Next Renewal" date.
I will def. do that. 😉
03-25-2019 11:10 AM
@danlee wrote:I am an exisiting customer and would like to change my plan, my next billing date is March 27/28, 2019. If I change my plan today, will PM start my "new" plan today or Mar 27/28 after my old plan expires?
03-25-2019 11:06 AM
@danlee a écrit :I am an exisiting customer and would like to change my plan, my next billing date is March 27/28, 2019. If I change my plan today, will PM start my "new" plan today or Mar 27/28 after my old plan expires?
But you can already chose it ..if you go in your self serve account on the 1rst page CHANGE MY PLAN you will have the choice to do it THE NEXT RENEWAL DATE and you will be sure to have this new plan even if it disapeared later...![]()
03-25-2019 11:04 AM
It's always better to do a change FOR THE NEXT RENEWAL DATE .If doing earlier you will not have your rewards for the 1rst payment..but for the next...
03-25-2019 11:04 AM
Yes, if you'd like changes to be in effect immediately, you can do that. Just be aware as already pointed out that there's no proration and you don't get funds back for an unused portion of the plan.
The more advantageous option is to change the plan upon next renewal. I've done that a few times to take advantage of more appealing plans than the one I signed up for initially. Works like a charm each time.
03-25-2019 11:02 AM
When you do the plan change you have the choice for the plan change to take effect immediately or on the next renewal date. Make sure you pick next renewal date so that you don't lose what you have paid for your current plan.
