03-25-2019 10:10 AM - edited 01-05-2022 03:55 AM
Hello, I'm getting the following issue when I try to call 1-401 and 1-845 numbers. Can someone please help? Btw My plan includes unlimited Canada wide calling....
" sorry you don't have an active long distance add on"
03-25-2019 10:29 AM - edited 03-25-2019 10:30 AM
@KateH wrote:Yes, I'm in Canada, trying to call into a conference for work. The other people on the conference are also in Canada. However, If the conference numbers mentioned below are US numbers that would explain the issue.
What type of phone to you have?. If it's Android you can download and use Hangout Dialer to call any North American number for free.
Also, you can add 200 minutes of U.S. & Canada Long Distance to your plan.
Purchasing Add-Ons is a 2-step process:
For more info click here
03-25-2019 10:27 AM
03-25-2019 10:23 AM - edited 03-25-2019 10:24 AM
@KateH a écrit :Yes, I'm in Canada, trying to call into a conference for work. The other people on the conference are also in Canada. However, If the conference numbers mentioned below are US numbers that would explain the issue.
If you want US calls included in your plan in Canada you need the 50$ plan per month.![]()
03-25-2019 10:22 AM
03-25-2019 10:18 AM
@KateH wrote:Hello, I'm getting the following issue when I try to call 1-401 and 1-845 numbers. Can someone please help? Btw My plan includes unlimited Canada wide calling....
Are you trying to call a US number from Canada or are you in the US?
03-25-2019 10:17 AM
They are both in the USA I believe. Your unlimited Canada wide calling would only be for Canadian Area codes.
Yes well thought @duffer900 !! For calling to the Us you need @KateH US roaming add-on...
03-25-2019 10:15 AM
Sometimes restarting your device fixes the problem.
03-25-2019 10:15 AM
03-25-2019 10:14 AM
@KateH a écrit :Hello, I'm getting the following issue when I try to call 1-401 and 1-845 numbers. Can someone please help? Btw My plan includes unlimited Canada wide calling....
Can you see your right plan in your self serve account? Is it just with those numbers? If yes you will need to reach the moderator here https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437 and explain what happened. Waiting time is few hours to 2 days..
