07-28-2025 04:27 PM
Hi,
My cell service has dropped down over the last few months. I have 2 phones in the house.
1 iPhone 13 shows SOS 90% of the time at home. While the Google pixel 6 show 1-2 bars most of the time. I notice today in town I had no signal for about 10 mins. Its back again.
We tried the basic steps
All software patches are applied
Removed cases
Rebooted phones
Swapped SIM cards
Turned off the cellular and turned back on...turned on airplane mode and back off
My sister called today and her and her husband are having the same problems. She said it's been going on for about a month. I think ours is more like 2 or 3 months.
I'm not sure is this is the right place to post or ask for help.
07-29-2025 04:07 PM
Straight line to a telus tower I'm 1.4 miles according to google. I'm the blue dot in the picture.
I'm going to try and reset the worst phone tonight. Wipe everything and see what happens.
07-28-2025 08:43 PM
Maybe try a network reset of your phones. Note: this will erase your saved Wifi passwords.
Or you could check the cell phone tower map to see where is the nearest cell tower:
07-28-2025 04:57 PM
Yeah I have 1 phone on 4g for a week no improvement.
07-28-2025 04:49 PM
hi @roydaigle
try the different network mode on the phone: 5G Auto, 5G On, 4G (or LTE)
07-28-2025 04:48 PM
😁 other side of the country Quispamsis, New Brunswick .
It was good when I moved here 6 years but terrible now.
07-28-2025 04:42 PM
hi @roydaigle
if for multiple phones, it could be a network problem in your area. Where are you at?
check if you see any outage where you are:
https://www.telus.com/en/bc/outages
quite some area in AB has problem with Mobile
