Transferring from Telus
G69
Hello
I'm switching to public from Telus. I made the request at 1045am. Most things seem to be working but not all. I can recieve texts from an Android phone but can't reply to them (I have an iPhone).
I've tried restarting multiple times. Just not sure if it's time or something else i should try. Thanks
G69
Solved! iPhone was still showing two carriers in my settings. When I disabled Telus, everything worked properly.
will13am
@G69 , check your iMessages settings.  Android devices cannot communicate via iMessage.  Also ensure that you have RCS enabled for texting.  RCS can take several hours to work.  It is a google thing.
G69
Yes I recieved a phone call. How and where do I remove my phone number in settings?
@G69
Did you reply to the text with YES from Telus confirming you are porting over to PM? There is a 90 minute for you to reply.
The Telus SIM will continue to work up to 4 hours until porting is completed. Once it stops working then switch to the PM SIM and reboot your phone.
Sansan
It's possible that a reset networks might be needed.
Also ensure that you remove your Telus SIM card.
Also in settings enable messages as sms.
hi @G69
forget about text between iPhone to Android for now
important question, can you receive inbound calls?
if you receive inbound calls, and just the text is a problem.  Go to Settings, remove the phone number first.  Reboot phone.  Then go back to Settings and add the phone number back to re-register iMessage
