08-22-2025 09:10 AM
Since switching my plan a few months ago, I've lost all cell reception. My signal strength is -111 bdm. Ive changed it in my settings to only use LTE because there is supposed to be coverage in my area. But I can't make a phone call. How do I fix this? I can't revert back to my old plan.
08-22-2025 09:36 AM
if you have a S24, the 3G band change issue won't impact you as you will be using VoLTE
Try Reset network settings after a phone reboot and see if it helps
You can also test your sim card with another phone.
And if nothing works, I suggest you to submit a ticket with CS_agent and ask them to reprovision your account:
08-22-2025 09:25 AM
I have a samsung galaxy S24. It's on the list. I think data still works. Texts come through. And I don't usually have issues with data. Does this mean I have zero options aside from switching to Bell? All because I changed plans? Why didn't they warn me? I could have left it as is
08-22-2025 09:17 AM
does data work? or just voice calls not working?
What phone do you have?
If your phone is not on PM's VoLTE whitelist ( https://www.publicmobile.ca/en/on/get-help/articles/volte ) , then it will be using 3G for voice and it might be affected by this:
Telus is currently refarming the 850MHz band 5 spectrum and hence you are left with 1900MHz for voice calls.
https://www.publicmobile.ca/en/get-help/articles/850-turndown
While one compatible band is still sufficient, reality is 1900 MHz could have less coverage, depending on your proximity to a tower and hence you are seeing a poor or no coverage with voice (Data is not impacted as your phone has the compatible bands on 4G/5G)
If this is really what affecting your voice calls (but mobile data still works) , there is really nothing much you can do other than getting a phone that is on PM's own VoLTE whitelist.
