09-18-2025 10:06 AM
Hi everyone,
Over the last month or so I have been having issues with my service, mostly at work. I work in Whitby, Ontario fairly close to Lake Ontario. Now when I am inside the building I have next to no signal, to the point where I can not send text message (SMS). I even have issues watching YouTube videos outside there. I have been working there for almost 10 years and never experienced it before. I was at the Oshawa Lake Park on the weekend and had the same result. I am using an iPhone XR with eSIM.
09-18-2025 11:27 AM
The iPhone XR doesn’t have 5G. Only 3G and 4G/LTE.
09-18-2025 10:36 AM - edited 09-18-2025 10:38 AM
Assuming that you are using a green Telus tower….are you close to one?
09-18-2025 10:20 AM
PM does have a good coverage in that area based on their coverage map.
Most likely building structure blocks signal... Check with your colleagues how is their coverage if they use the same or other providers.
09-18-2025 10:08 AM
hi @Cdnfenix36
Try Reset Network Settings and see if it helps
if not, ask PM support agent to refresh your account on the system side for you
submit a ticket with CS Agent using Chatbot here:
Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
(If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, you can submit ticket by direct message:
09-18-2025 10:08 AM - edited 09-18-2025 11:37 AM
try manually selecting 4G or LTE instead of 5G...see if that helps.
