03-23-2021 09:22 AM - edited 01-06-2022 01:32 AM
Hello.
Not a new member have had my service for awhile and yesterday I stopped being able to send and receive text or phone calls.
My bill is paid
My Phone is a Samsung S10e
I've tried Simon suggestions for restarting phone and reinserting the sim card
Any help would be great thanks a alot!!
03-23-2021 04:03 PM
@computergeek541 wrote:
@esjliv wrote:
@CoreyBurns wrote:Hello.
My bill is paid
I would be concerned about SIM fraud, after reading your post. I hope it is not!
Good suggestions by others. Please follow the trouble shooting to see what the fix may or may not be.
See info. here (I believe @HALIMACS lists this check in one of their points as well):
https://www.publicmobile.ca/en/bc/get-help/articles/sim-swap-fraud
I don't believe that's the case here. Unless the customer doesn't use data, the OP would likely also be saying that data doesn't work either.
@computergeek541 maybe, maybe not. I am sure there are many mobile users out there that don't even toggle on their data capability.
03-23-2021 11:59 AM
That's the magic question, @computergeek541 & @esjliv
The subject line says "can receive them fine", yet the post suggests "stopped being able to send and receive text or phone calls", so there's some discrepancy here.
03-23-2021 11:46 AM
My bill is paid
03-23-2021 11:30 AM
which plan you have, maybe you already used up all text messages, but you still can receive, not send. if this is not the case, try re-boot your phone.
03-23-2021 10:28 AM
My bill is paid
03-23-2021 10:10 AM - edited 03-23-2021 10:23 AM
Try this step-by-step troubleshooting (some may be irrelevant, i.e. #5):
03-23-2021 09:43 AM
In addition to Dunkman's excellent suggestions, make sure all of your apps are updated as per https://www.theverge.com/2021/3/22/22345696/google-android-apps-crashing-fix-system-webview. There were some weird symptoms happening yesterday and this morning for some folks on Android but the updates should fix it up.
03-23-2021 09:29 AM
A few things to try:
Network reset of phone
Toggle airplane mode on, then off
Can also try your SIM card in another phone. This helps determine whether hardware setup issue versus PM service problem.
