Cant send or receive messages
Lackey250
I have checked my APN settings in accordance to all the posts and chat help on Public Mobile and they are correct. I've been a customer with PM since 2016 and have only had issues wen I forgot the change the APN after switching my phone. I haven't switched my phone in over a year. The only thing that changed was I had to change my payment method in my subscription. I have restarted my phone more than once as well. I don't know what to do.
Lackey250
OnePlus 9 Pro 5G. I have updated the APN to what you posted and restarted again and it finally sent.  Thanks!
@Lackey250 whatmodel of phone is that?  Again, a delete APN, re-add new one with the parameters above should work.
Worst case, support could make it work if your phone is not older than 2017.  Just open ticket with PM support:
1. Open ticket via Chatbot (need access to My Account): At https://widget.telus.tiia.ai/publicmobile/publicmobile.html
    Start by typing "Submit a ticket", then click "Contact Us", then "Other", then "Log In", finally click "Click here to submit a ticket ↗
Lackey250
Hmm my phone was an unlocked sprint phone I purchased 2 years ago. ...it sounds like that is why it no longer works. That is RIDICULOUS if that is the case!
@Lackey250
what phone do you have?
Not sure if your phone is affected by this announcement:
https://productioncommunity.publicmobile.ca/t5/Announcements/Picture-and-Group-Messaging-End-Date-Fe...
if you are using a device that released after 2017, generally, you can simply click Reset All networks or Reset network settings to get the latest APN
but if that does not work, there might be a bit more work than simply updating.  Many confirmed that you need to delete the current APN profile first.  Then Add new profile and add according to this, please note case-sensitive and do not add extra spaces.  Remember to save the new APN and then reboot the phone first
APN: sp.mb.com
         (or try all upper case SP.MB.COM)
Proxy:
Port:
Username: <blank>
Password: <blank>
Server:
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
MCC: 302
MNC: 220
Authentication Type: Not Set
APN Type: default,supl,mms
         or    default,mms,agps,supl,fota,hipri
           (might need to include DUN for hotspot, please note case sensitive)
APN protocol: IPv4
APN roaming protocol: IPv4
APN enable/disable: APN enabled
                or  Turn APN on/off APN turned on
Bearer: Unspecified
MVNO (Mobile virtual network operator) type: GID
MVNO (Mobile virtual network operator)value: 4D
Chalupa_Batman
Have you tried placing your SIM card into another phone to see if it works??
