Thursday
- last edited
Thursday
computergeek541
Could not receive or call all day. 17h15 it work for few minutes. Just enough time to read my recorded message sent this morning. Then down again. Could not receive your MSM for the code . Add to use email.
Message: Emergency calls only
Thursday
It may be related to Telus outage, Many customers have reported the same problem.
Thursday
Try reaching out to support @GJ50:
Thursday - last edited Thursday
If you are using a physical Sim card, can you try the Sim card in another device to see if service works?
and to confirm, all services were previously, correct?
Alternatively, can you try another person Sim card in your device to see if all their services work?
Thursday
Nothing is working. No talking, no msm
Thursday
No
did you just move to the service from another provider?
If so, did you reply yes to the port authorization text within 90 minutes with your old provider Sim card in your device?
Try rebooting your device and resetting network connections.
does texting work either way and what about your data?
