05-06-2023
05:34 PM
05-07-2023
12:07 AM
computergeek541
I can not send a text message to a 6 digit short code. I keep getting "Can't send with public mobile - error 0"
I am using a Samsung S10
Premium text message setting is on
I have a monthly unlimited call and text plan.
05-07-2023 02:33 AM
@BL89 yes, the shortcode is there and it should work.
I tested it myself by sending STOP and it works
did you ever got it working?
Regular texting work? you able to send other shortcode?
if you have another phone, test the PM sim there and send the code
If it still does not work, I suggest you to open ticket with support have them to investigate further
1. Please open ticket via Chatbot (requires access to My Account): click this Chatbot Ticket Link
Then click "Click here to submit a ticket ↗" to open the ticket submission page
Next, enter your Community login, then enter your question. Finally use My Account login or 4 digits PIN to validate.
2. If you have trouble with Chatbot or you don't have access to My Account: Private message CS Agent at:
05-07-2023 12:36 AM
The short code 959959. Which is on the list.
It's a radio station and I'm not sure how everyone else is able to text to the number.
05-06-2023 05:36 PM
@BL89 what short code is that? you see your code here? only codes found in this site are supported
