Cant make a call
Itemple88
Hello,
I have a unlimited provincial call but i cant make a call since i have used all available minutes?? Whats going on? Why is this happening all of sudden? Pls explain!!!
9 REPLIES 9
Tox1c
If you are using android there is a app called "carrier services" it will not be in the app drawer go to settings > apps uninstall the updates and clear the app data.
It worked for me, I wasn't able to make phone calls to landline numbers
@Itemple88  It has been couple hours, is the service working again this morning?
Try to make one more reboot.
Also, can I confirm if incoming calls working without issue? Mobile Data working?
What exact plan you are at? You said you have unlimited minute, so it is not $15, right?
And you said you have an unlimited provincial plan?  at least for future, consider consider changing it to the current Canada-Wide Calling plan.  I believe your activated last year when Provincial Wide calling were introduced, PM was trying that but failed in couple weeks and changed everything back to Canada-Wide Calling.  It should be the same price but you can call everywhere for free instead of just within province
@Itemple88  - we are customers and members like you here on the public forum.
Are you able to text back and forth with your wife without issue?
Since this affecting you both it may be a localized network issue, that my resolve itself on its own.
Someone yesterday had the same problem calling their spouse (seemed locally) as well. Adding a '1' in front of the phone number helped them, although they never had to do that before.
You will not get charged anything for added the '1' in front, since this is a prepaid service.
Occasionally, toggle into airplane mode or restart your devices to see if something resets/or retriggers the network.
If still issues you can each inquire with PM representatives, contact methods found here: https://www.publicmobile.ca/en/on/get-help/articles/contact-an-agent
Curious, what plans are you on and when did you activate? Perhaps you activated early 2021 on provincial plans? Please know now all plans are currently Canada-Wide calling for the same price (or maybe better, depending on your activations dates).
You may want to look into scheduling a plan change on your next renewals if this applies to you.
darlicious
@Itemple88
You are in Ontario calling an Ontario number correct?
To pre-verify your account include your full name, address, email, phone # and 4 digit acct pin #
darlicious
@Itemple88
Power off your phone. Leave off for 10 minutes. Power on and try manually dialing your spouse with (1) in front of the number. If it continues to be an issue contact customer support. If its an emergency and you must use your phone before morning purchase the $5/500min add on and ask for it to be credited back when you talk to customer support. This was the work around when this issue last crept up a year or so ago and previously in 2018 with province wide calling plans.
Itemple88
Tried it but still no luck,, it still says i have used all available minutes,,,(i have a unlimited provincial plan)
Itemple88
Located in Ontario, i have a same plan as my wife has, her phone works totally fine,
ive attempted many times to make local calls it still says i have unavailable minutes even though i have unlimited provincial plan,
@Itemple88
Hmm, either there is a glitch in the system or a system outage.
Where are you located?
Can you make a local call?
Or maybe try using VoIP in the interim.
This is a likely a temporary issue with Public Mobile's systems. If you dial 1 and then the area code before the number, it might work.
