05-08-2019 12:59 PM - edited 01-05-2022 04:50 AM
I have received a call from public mobile to finish changing my number over from another provider. I tried to sign in to public mobile online to access my account information. I get a error message saying that there is a problem with my email. Any help ? Also, my phone crashed while I was activating the sim card. Is this part of the problem? Do I need a new sim card ?
Joining Public
05-14-2019 01:21 AM
The moderators are great and will be with you as soon as they can! It may take a day, but they will get you sorted.
05-13-2019 10:31 PM
Hi all,
I have just ported my phone number from Koodo Postpaid to PM yesterday. My Koodo has switched to the temporary new number that I created when activating my PM sim card. However, my PM sim card is getting "no service". I have paid for my first month plan in PM (15 buck per month), lost my old phone number, and I still can't login into my PM account. I tried forgot password option and got this error "ForgotPassword/LoginUnsuccessfulUser_LoginDisabled".
My friend, who referred me told me that he received 2 messages from PM yesterday: the first one to say that I have joined PM. The second one to say that I have left PM. I have tried to contact moderator team but has not received any response after 24 hour.
Can anyone else help me?
Thank you!
05-12-2019 06:37 PM
All straightened out! Thanks for all your help. Great community!!
05-12-2019 05:58 PM
@Shea84 Please see below for the reply from the Moderator team.
05-10-2019 01:03 PM
Alright then, in this case, can you please let me know once you have your phone working with the PM sim card? And then we will e able to work on your self serve account as well.
I will be waiting for your reply. 🙂
Beatrice.
05-09-2019 08:44 PM
@Shea84 wrote:it is asking for a netwrork PUK code ... i didmt notice that until you mentioned it !!! on the phone with old provider currently. you are a saint. thank you
That isn't the sim card's PUK. That message means that that your phone is locked to a different carrier. Public Mobile does not have access to that code.
05-09-2019 07:33 PM
05-09-2019 07:23 PM
05-09-2019 07:17 PM
@Shea84 Have you ever set up your account with public mobile online? if not, you'll need to start there and register the SIM card #. If the SIM card still needs to be unlocked, I'd suggest maybe waiting for a moderator to get back to you. As @geopublic mentioned, it does take approx 2-48 hours for the @CS_Agent to get back to you, but they definitely will!
05-09-2019 07:12 PM
when i attempt that it says my email doesnt exist
05-09-2019 07:11 PM
SIM is locked and need a PUK code, one was provided by PM but does not work
05-09-2019 07:07 PM
@Shea84 you can always enter your email address that you used to set up your online account and click FORGOT PASSWORD and reset your information that way to login online.
05-09-2019 07:02 PM
@Shea84 wrote:I have received a call from public mobile to finish changing my number over from another provider. I tried to sign in to public mobile online to access my account information. I get a error message saying that there is a problem with my email. Any help ? Also, my phone crashed while I was activating the sim card. Is this part of the problem? Do I need a new sim card ?
@Shea84 The message from Public Mobile that you received regarding your port (phone transfer) is because Public Mobile needs additional information (account information) from your previous provider in order to complete the port.
So I'm assuming you already sent them that information. The fact that you can't sign-in to your selfserve account is another issue. Were you trying to activate your sim using your phone's browser when it crashed? If yes, then that might be the reason why you can't access your account. Since you contacted the moderator regarding the port and account access, moderator response depending on volume requests can be from 2 - 48 hours.
A couple of more questions:
Does your phone connect to the PM network?
Can you currently make outgoing call send texts?
05-09-2019 06:40 PM
how long does it usually take for a moderator to answer?
05-08-2019 01:11 PM
All 3 links work you have to enter subject and message.
05-08-2019 01:10 PM
@Shea84 wrote:I click your link, but there is no where to type a message, how do I continue into a private message with a moderator?
You'll see that moderator_team is pre-filled. Then you'll need to type in some kind of subject. Then a little further down is the message body box under the little icons to type in.
Naturally of course you need to be logged in to the community to be able to but you already are seeing as how you're posting here.
05-08-2019 01:10 PM
Sounds like something is up with your browser. I can click either of the links and they both work...
Are you at work? Maybe restrictions.
Did you try incognito mode if you are on Chrome?
- On your computer, open Chrome.
- At the top right, click More
New Incognito Window.
- A new window appears. In the top corner, check for the Incognito icon
05-08-2019 01:08 PM - edited 05-08-2019 01:09 PM
You can type your message in...MESSAGE BODY...and they will answer you and you will see a little 1 in red in the little envelopp ( for private message) right up on this page.
05-08-2019 01:07 PM
05-08-2019 01:05 PM
You could try logging in using incognito mode. If you are still having problems then you may need to contact a moderator.
Moderator can be reached at
05-08-2019 01:03 PM - edited 05-08-2019 01:04 PM
Try another browser?
Try incognito mode in Chrome
Clear the history/cache
If these fail, please contact the moderators
click here to private message a Moderator
05-08-2019 01:02 PM
You will have to contact the moderators to get access, you can send them a private message here: link
