10-31-2019 02:21 PM - edited 01-05-2022 07:48 AM
10-31-2019 02:47 PM
@SilvaG wrote:yeah hes a local. were both living in toronto. Ill contact the moderator, thanks for your help
If dad's number is very new today, it might take a while for it to activate the calling part, especially if he's ported his old number. Tell him to restart occasionally to perhaps get it going.
10-31-2019 02:43 PM
10-31-2019 02:43 PM - edited 10-31-2019 02:46 PM
Nvm, read your post incorrectly.
10-31-2019 02:41 PM - edited 10-31-2019 02:42 PM
Check to see if his area code is local. If it is, you'll have to click the ? in lower right side of the screen to start process of contacting a moderator to assist. Type "contact moderator" and follow instruction.
You can also consider getting that $5 / 500 minute Canada wide add-on I mentioned.
10-31-2019 02:40 PM
"don't have long distance add-on"
10-31-2019 02:38 PM
@SilvaG wrote:this is a new problem. My father just got a new phone number with freedom mobile. Hes able to call me and were able to text eachother. But when it comes to calling my father, it automaticlly goes to automated voice over for long distance call.
Is the message saying that long distance may apply or is if saying you don't have long distance add-on? The first type can be ignored.
10-31-2019 02:37 PM
10-31-2019 02:32 PM
@SilvaG wrote:I've got unlimited provincal talk plan
Have you been able to call him before or is this a new problem ?
10-31-2019 02:32 PM
Are you able to call other numbers ? Try rebooting your phone.
10-31-2019 02:31 PM
@SilvaG wrote:Im trying To call my fathers phone number but when I call it thinks hes a long distance contact, I put the number 1 infront of his phone number just to make sure it was because of that but still hasnt worked.
If he has a number in the same province, it could be a provisioning problem. Are you traveling within Canada?
10-31-2019 02:29 PM
10-31-2019 02:24 PM - edited 10-31-2019 02:26 PM
Check to see if you've run out of minutes...if you have a $10 or $15 plan.
If you've run outta minutes you can get the $5 / 500 minutes of Canada wide calling add-on. Those minutes don't expire but roll over month after month until you use the 500 minutes up.
