Cannot to receive call and text
Khadijeh2
I have problem in get text and call. Can you help me
2 REPLIES 2
@Khadijeh2
There could be a possible outage in your area so check the outage map:
https://istheservicedowncanada.com/status/telus/map
If no outage then contact a CS_Agent.
Sansan
Did you recently join Public Mobile? If so Did you receive a text from your previous provider and confirmed the port?
You can contact them at the link below to see what's happening.
https://widget.telus.tiia.ai/publicmobile/publicmobile.html.
If you encounter errors with that link, the the next one below.
They will reply via your community mailbox.
