04-07-2023 11:23 AM
Cannot switch from base 3G plan to 4G/$40 plan--it just spins and spins, never activates. Tried last 3 days, over and over.
04-07-2023 01:21 PM
I was on pc, tried on iPad, same result. But Leonardo at pm, accessed per your recommendation did it for me and says it wail switch on renewal date. Thank you again for yr suggestions.
04-07-2023 11:47 AM
Hi @Navy11 were you accessing the page using phone or computer?
can you use the other one to test once more? You could have different outcome
if still does not work, please submit a ticket
04-07-2023 11:39 AM
04-07-2023 11:35 AM
Hi @Navy11 if you still cannot make the plan change, submit a ticket with CS agent:
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
04-07-2023 11:27 AM
Try using different browser. Try Incognito/private mode. Clear browser’s cache. Try forced refresh. Use computer and not phone to log in.
04-07-2023 11:25 AM - edited 04-07-2023 11:25 AM
@Navy11 there were posts about the spinning problem when making plan change. You are scheduling for plan change at renewal date?
Please try again using Incognito mode and see if it works that way
If using incognito mode does not help, it could be a system issue rather than browser, you might need to have PM support to schedule it for you
