Cannot send SMS
06-19-2019 07:15 PM - edited 01-05-2022 08:06 AM
I changed my plan from $10 to $15. I can't receive and make calls as well as receive text messages but I cannot send text and my mobile data is not functioning and useless.
Service
07-11-2019 01:07 PM
@peachessstall Hopefully, you contacted the Moderator_Team by now (as suggested in earlier posts) and your data is now fully functional.
07-10-2019 10:09 PM
Yes. It does have
07-09-2019 01:27 PM
@peachessstall, when specifically did you change to the $15 plan. There were two versions of this plan, one being offered during early May, the second late May and continuing to date.
IF you change (future dated or immediate) in early May, you're on the old one. You should schedule a plan change again for the current $15 plan.
The best way to verify this is by looking at your payment history and the 'plan detail' of your plan, both in 'My Account'.
07-09-2019 08:41 AM
07-09-2019 08:30 AM
It doesnt help
07-09-2019 08:30 AM
It shows as active and yes my plan is the $15. The plan says that I have unlimited text
06-19-2019 08:07 PM
What does your self service account show? Active or suspended? Which plan? $15 plan should show 100 Cdn minutes and 250 mb data in the add on section in overview page.
06-19-2019 07:58 PM
@peachessstall wrote:I changed my plan from $10 to $15. I can't receive and make calls as well as receive text messages but I cannot send text and my mobile data is not functioning and useless.
Your new plan features may not be provivsion correctly. Try the lost/.stolen phone trick to run the provision software again.
1. Login to your self-serve account.
2. Report your phone lost/stolen using [Plan and Add-Ons] --> [Lost/Stolen Phone]
3. Logoff
4. Wait 5 minutes and login again
5. Report your phone found.
6. Re-start you phone to provision your account again. i.e. enable all features of you plan again.
If this trick failed to get thing working again, you should send a private message to moderator for help. But the wait is up to 48 hours. Good luck.
06-19-2019 07:24 PM - edited 06-19-2019 07:25 PM
You can try rebooting your phone. Another option to try is the lost/stolen trick, log into your account, select plans/add-ons, select phone lost, suspend, log out, wait a few mins, log back in, unsuspend phone. Log out and reboot your phone. This sometimes resets the account.
One other thing is to add $1 top up to your account and restart phone. Otherwise contact the moderators for help.
06-19-2019 07:21 PM
Cycle phone off/on.
Let us know if that helps. Good luck.
06-19-2019 07:18 PM
You will have to contact the moderators to get access, you can send them a private message here: link
Moderators can take anywhere from 2 to 48 hours, depending on how many customers are ahead of you.
