01-05-2023 06:46 PM
Hi,
I'm trying to login into my Public Mobile account but it says that my password is incorrect. So I tried to reset it, but the email with the code is never sent to me. Can someone help me here?
Thanks,
Matheus
01-05-2023 08:30 PM
@matheusota wrote:Hi,
Thanks,
Matheus
@matheusota - Note, if you have been in nonpay/suspended status for over 90 days, or ported your Public Mobile number to another provider, then you lost your Public Mobile account, phone number, and access to self serve/My Account.
Otherwise, see other's posts.
01-05-2023 06:50 PM
@matheusota @sounds like you need a agent
Getting help from agent , through automation
Or get direct help from a agent right here in the community ( my preferred choice )
01-05-2023 06:49 PM
Try logging into your account using a different browser in incognito or private mode instead.
Try looking for the link in your junk or spam folder.
01-05-2023 06:48 PM
Try using different browser. Try Incognito/private mode. Clear browser’s cache. Try forced refresh. Use computer and not phone to log in.
If you reset your password, wait at least 20 min to try to log in again.
If everything fails, contact agent for assistance:
To Contact CSA-agent; there are 2 methods:
Ticket has to be opened through chatbot - https://widget.telus.tiia.ai/publicmobile/publicmobile.html
If ticketing does not work very first time, contact agent directly.
- Send a private message to the CSA - agent by clicking (Ctrl+)Here
01-05-2023 06:47 PM
@matheusota check your spam folder
If that still does not work, then open ticket with PM support using Charbot and they will sort it out for you
1. Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
Start by typing "Forgot Login Information", then click "Contact Us",, then click "Click here to submit a ticket ↗"
2. if you have problem with Chatbot: Private message CS Agent at:
