Cannot receive text message and phone call
11-30-2023 09:42 AM - last edited on 11-30-2023 05:58 PM by computergeek541
I switched from Rogers to PM and replied Yes to Rogers confirmation message.
however, right now I can only call and message others. No messages or phone call can be received. It looks like it might be a porting issue. Is there a way I can re-port it? Thanks!
Joining Public
11-30-2023 11:11 PM
Hello, thank you for the response. I contacted the porting team and responded to new Rogers transfer message right away. However, it is still mixed usage: cannot receive text or phone with Public Mobile
11-30-2023 12:02 PM
Did you have a ROGERS SIM card and then added the PM eSIM? I had issues when switching from a physical SIM Card. I took the SIM card out, and rebooted my phone (iPhone) and it seemed to sort itself out.
11-30-2023 10:23 AM
Hi Softech,
I am experiencing the same issue - I ported over a week ago but did not notice I was not receiving call or text. May you please forward the number to me as well? I was contacted by the porting team but when I call back it says "there is no porting in progress" or something like that.
Thank you
11-30-2023 09:44 AM
first, reboot your phone once and test incoming calls again
if still fails, how long you replied YES to Rogers? Usually it can be another 1 to 4 hours before the line will be ported over after a YES reply. so, if it is 4 hours yet, reboot phone every 30 mins and test incoming calls
If over 4 hours, call the porting team for update. I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) . Check the envelope icon on top right. Call them and get it fixed
