Cannot receive or send pictures
03-25-2019 10:42 PM - edited 01-05-2022 03:56 AM
03-27-2019 09:59 PM
@iainkelly wrote:Hi There, we've got a plan that is meant to include sending and receiving picture messages but it absolutely doesn't work. We've tried all kinds of things! Please help!
Up until recently, I had the same problem. All I did was enable my data and the problem was solved. If this does not work, then you may have to look into your APN settings.
03-25-2019 10:53 PM
Check your APN settings, they should look like this:
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
Don't forget to save these settings and then select this APN as the active one.
03-25-2019 10:47 PM
Did you enable data on your phone? MMS needs data enabled.
03-25-2019 10:46 PM
The is likely an issue with the APN settings on your phone not being set correctly.
Some information provided by Public Mobile is shown here: https://productioncommunity.publicmobile.ca/t5/Phones-Hardware/How-do-I-set-up-data-APN-on-my-smartp...
Depending on which phone model you have and the software that it runs, slight variations of the settings might be required.
