Cannot reactivate my payment
melnykalyssa
I cannot access my account (cannot find my username) to reactivate my payment.. Any suggestions?
HI @melnykalyssa   login to My account would be an email address, please try it.  If it is just password, you can reset the password yourself
or if you really cannot find the username (email) or password,   then submit ticket to CS agent at : https://publicmobile.ca/chatbot.
First type Forgot Login,
@melnykalyssa
Your user name is your registered email address. Login with it and click on Forgot Password.
@melnykalyssa   how long you have your plan suspended?  If over 90 days, the account would have been permanently closed
If less than 90 days of suspension, just try reset the password
First try to use the Reset Password link there on the login page (or direct link: https://myaccount.publicmobile.ca/en/forgot-password) enter any possible email addresses you could have used and see if it works
If you are unable to self reset the password, PM support will be able to help
1.  Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
Start by typing "Forgot Login Information", then click "Contact Us",, then click "Click here to submit a ticket ↗"
2. if you have problem with Chatbot: Private message CS Agent at:
