US Roaming Add On
sprky
Can I call back and text back to Canada with The US Roam $30.00 add on
2 REPLIES 2
HI@sprky   yes, you can call both Canada and US with the roaming
make sure you connect to T-Mobile network.  Try to use VoLTE first (enable VoLTE on your phone)
if that does not work, then try using the 2G network by manual select Network type to 2G
@sprky
Yes you can.
