05-24-2022 08:11 AM
Hi I travelled to sri lanaka used a local sim card on my phone. I came back put my Public mobile SIM card back and I have tried a factory reset and a network reset. I have checked my APN settings. I was wondering if there is anything further I can do. I am unable to make calls when I make a call it says emergency calls only. The SIM card has been reinserted restarted the phone.
05-24-2022 08:30 AM
@vjjvv How long you have left the country? have you be paying PM service while you were away?
Please login to My Account and check the account status first. Make sure it is showing status Active and not Suspended
Also, it would be nice if you have another phone to test, just put the PM SIM in the other phone and see if it works
05-24-2022 09:26 AM
APN settings should not affect voice calls, just data functioning.
As mentioned above, try your PM SIM card in another working phone. That helps determine whether hardware issue versus Public mobile service problem.
Any chance your phone was blacklisted while you were away?
https://www.devicecheck.ca/check-status-device-canada/
05-24-2022 10:26 AM
If you were gone and haven't renewed your account for over 90 days it will be deactivated and your number lost.
05-24-2022 11:00 AM
What your self-serving account says regarding your status? Is it Active?
If it is suspended due to no pay for less than 90 days, pay Plan's fee and reactivate service/account.
If it was suspended longer than 90 days, your account has been closed, number lost.
