04-03-2023 11:09 AM
I cannot make and receive any calls. I’m on monthly auto pay and my minutes never exceed every month
Service
04-03-2023 02:44 PM
@ehung7 there has been some voice problem last couple days, maybe it is time to open ticket with PM support:
1. Please open ticket via Chatbot (need access to My Account): click this Chatbot Ticket Link
Then click "Click here to submit a ticket ↗" to open the ticket submission page
Next, enter your Community login, then enter your question. Finally use My Account login or 4 digits PIN to validate.
2. If you have trouble with Chatbot or you don't have access to My Account: Private message CS Agent at:
04-03-2023 02:44 PM
HI @ehung7
Submit a ticket with PM agent , hope they find what's wrong
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
04-03-2023 02:43 PM
I don’t have a computer with me right now.
04-03-2023 02:41 PM
Try everything, still doesn’t work
04-03-2023 02:40 PM
I’ve tried it, still doesn’t work
04-03-2023 11:50 AM
Check your online account if it’s active and still have calling minutes left. If this 2 are in affirmative and still can’t make a call, remove and reinstall your sim and restart your phone, this worked for my wife when she had similar problem
04-03-2023 11:50 AM
04-03-2023 11:24 AM
Log in and confirm you still have minutes available.
Try using different browser. Try Incognito/private mode. Clear browser’s cache. Try forced refresh. Use computer and not phone to log in.
Is this recent issue or it happened before?
How many signal bars do you see?
Can you try SIM in another phone and vice versa?
04-03-2023 11:11 AM
@ehung7 can you login to My Account once again, but this time login using Incognito mode
Confirm if the account is active or suspended. Just worry it didn't renew properly
If it is active, try to reboot the phone once
Confirm if the phone can connects to PM network
You might also want to change your Preferred network or Network mode to 3G and see if it works
let us know
