08-14-2020 05:32 PM - edited 01-05-2022 12:32 PM
08-14-2020 06:46 PM
Hi @sstrauss
As mentioned, you can call 611 on your phone to enable or disable autopay on your account.
Check here to see what else you can do via 611 IVR menu: https://productioncommunity.publicmobile.ca/t5/Self-Serve/611-IVR-Menu-System/m-p/289352
If you need to regain access to your self-serve account, you will need to contact moderators for that.
08-14-2020 05:38 PM
@sstrauss to get back into your account. Contact the moderators and ask them to for a temporary password to your self service account. There are 2 ways to contact the Moderator Team:
Once connected to Simon, you will be asked to log in again with your community user name and password. Please do, this allows you to continue and send your message.
- Keep an eye on the envelope top right of your screen. The mods answer will show up there. When it does, you will be asked to verify your self service account, with your password and login. Doing so allows the process to continue. Stay safe.
08-14-2020 05:35 PM - edited 08-14-2020 05:36 PM
Call 611..press 5 to Remove Autopay.
08-14-2020 05:33 PM
Also wont let me in when i click on forgot password
