Cannot change plan - no options
Sojibby
Hi, I have topped up my balance to the required amount.
When I click change plan I get the correct page but it doesn't show my current plan nor any plan options on the other side
When I click other optiont above where the choice plans should be I get an error page about not being allowed access to that directory.
I have logged out and in, cleared my cache, and used incognito mode with no change in results.
Any help would be appreciated.
9 REPLIES 9
Dylan3
You should speak to a moderator about this and they can help you
fathermocker
@Dunkman wrote:
@fathermocker
Clearing cache or incognito mode are other options.  Website is finicky.  Trying on a different computer or device.  Chrome incognito seems to work well with this website.
Thanks! That did it!
@fathermocker
@fathermocker try using a different browser just to see
fathermocker
Hey! I have the same problem @Alan_K 😞 I can't change my plan because the Self Serve website shows no options
Alan_K
@Sojibby wrote:
Thank You.  It did sreem to be a server error or something on their end, but there did seem to be other regular plan issues mentioned so I wanted to be sure.
Hi @Sojibby , can you try again now and let me know if the problem persists?
Sojibby
GinYVR
@SojibbyI can confirm there is an issue with the plan change right now. I suggest just wait a while and try later.. it happens from time to time.
Triguy
Submit a ticket to a moderator by clicking on the question mark on the bottom right.
